ShoutChat Box
Lock-down Thread
by gfretwell - 05/08/21 01:39 PM
Do You Travel?
by gfretwell - 05/07/21 07:44 PM
Unemployment Fraud
by gfretwell - 05/07/21 07:28 PM
How's all our Non-US folks doing?
by grich - 05/07/21 06:04 PM
Where is Everyone?
by grich - 05/06/21 05:49 PM
2020 - 2021 Winter Project
Garden 2021
0 registered members (), 16 guests, and 17 spiders.
Re: Knee Deep Insulation & Accessibility #90168 11/02/04 10:22 AM
rad74ss Offline
I just finished a job where the previous homeowner blew in cellulose insulation that was waist high in places. No kidding! It was in snow drifts in the corners and the outside wall had a bank that was shoulder high! Luckily there was minimal electric in the home (i.e. no recepts or lights in half the house).
In a place like that you are more likely to find a rat than a j-box.
2017 / 2014 NEC & Related Books and Study Guides
Re: Knee Deep Insulation & Accessibility #90169 11/02/04 05:45 PM
ElectricAL Offline
A demographic rule of thumb that I picked up at the home improvement magazines I consult with: Over half of single family dwellings have been built since 1970.
Of the half built before 1970, a big proportion will be dwellings that will attract attic J-boxes. I see a lot of 'em. The core legacy circuit or two from a time of 30 Amp service entrances.
Al Hildenbrand
Re: Knee Deep Insulation & Accessibility #90170 11/02/04 06:10 PM
F
Fred Offline
In 2 story homes I wire, I routinely run a 1" EMT to the attic and terminate in a 12x12x6 pull box for the 2nd floor circuits. When I do this I mount the pull box in a central part of the attic where there is the most headroom and mount it on 24" 2x4 risors/plywood. This not only makes it easy to find in the future, it also keeps anyone from having to lay in cellulose to access it.
Re: Knee Deep Insulation & Accessibility #90171 11/03/04 08:38 PM
PCBelarge Offline
Since I have to put my name on the document, I crawl into every attic, crawl space for each inspection I perform that requires it. I will admit, I am the 'dirtiest' inspector I know [Linked Image] The contractors usually ask me 'what?' when I ask for a ladder for the scuttle hole [Linked Image]
Like I said my name is on that final document and it won't go on that document until I am satisfied the work complies with the MINIMUM code requirements.
The biggest problem I find in attics is 320.23
Pierre
Pierre Belarge
Re: Knee Deep Insulation & Accessibility #90172 11/03/04 09:35 PM
mustangelectric Offline OP
Hi,
Thanks for all the replies. I can remember a time ot two or three where I have seen boxes without covers, cables without connectors terminations without wire nuts and my favorite...a splice with a wrap or two of 33.
I also like where the new AC unit is tapped from the range wire or HW heater..
-regards
MUSTANG
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
sparky66wv
sparky66wv
West Virginia
Show All Member Profiles
Trumpy 15
Admin 8
278,691 Are you busy
211,890 Re: Forum
198,941 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
