Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
AFDD's coming to the UK
by Texas_Ranger - 01/17/23 07:22 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 27 guests, and 13 robots.
#8753 04/03/02 01:28 PM
Why can't they design a stud (2x4, 2x3) with pre bored holes for our wires and pipes ? Or do they and I have been doing it the hardway for all these years ?
Sort of like a metal stud with pre punched holes only made out of lumber.
Could I be on to something here ?
#8754 04/03/02 06:09 PM
The framers wouldn't line the holes up for you ,
just like metal framers [Linked Image]
I went to a wood framed job once where there were holes already drilled in the studs.
I thought the carpenters had done me a favor.
The GC said that it was Canadian lumber, and by drilling a hole in each 2x4 they became a "manufactured product" . Thus they were not subject to an import tax on lumber.
Can anyone confirm?
#8755 04/07/02 03:19 PM
Also heard similar reason from local lumber yard, less Tax, although he said they call it Used lumber because of the pre-drilled holes.
CMC
#8756 04/07/02 08:03 PM
We've had pre drilled studs for a while here. Just can't find any framers that have enough sense to turn them all the same way.
#8757 04/09/02 02:58 AM
We've had the predrilled studs here inTN for about five years. The big blue box store sells them,so they ain't used much. The first time we saw them I took a guy I worked with to go get some lumber and he got to a stack of them and started loading them when he realized they had holes in em. He showed me and said look somebody drilled em and brought em back. We didn't know the difference back then. The local lumber yard don't keep em. Now when can we get predrilled top plates 16" O.C., yeah right.
Lighting the way
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CDS
CDS
Nicholson Ga
BigB 8
triple 3
302,657 Are you busy
231,942 Re: Forum
216,602 Need opinion
