by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
#85568 07/15/03 09:37 AM
[Linked Image from users.stargate.net]
A picture is worth 1000 (curse) words...
[This message has been edited by sparky66wv (edited 07-15-2003).]
-Virgil
5 Star Inspections
Member IAEI
#85569 07/15/03 09:17 PM
Virg,
Has that same ole inspector been at it again? [Linked Image]
Donnie
#85570 07/17/03 06:39 PM
What am I missing? I didn't spot the problem.
Oops, now I see it. Those markings on the lugs are your original torque marks. Right?
[This message has been edited by tdhorne (edited 07-17-2003).]
Tom Horne
#85571 07/17/03 08:02 PM
explain it one more time please, cold flow, or whatever makes this a bad thing to do
#85572 07/17/03 09:53 PM
Sparky,
Look at this thread , and this one .
Don
#85573 07/18/03 07:09 AM
thank you Don.
in a perfect world, i'm agreeable to this ideal.
as to all the old work in the world, all bets are off....
allbeit, much of what is out there never realized a tourqe spec in the first place
#85574 07/18/03 01:41 PM
Tom Offline
Virgil,
You gotta explain to folks what it is like to have coal miners & ex-coal miners around. I've never met one that could resist tweaking any adjusment knob they've ever seen and it ain't tight 'till it squeeks & glows red. [Linked Image]
American measurements of torque- inch pounds, foot pounds & erks. Erk is the sound the fastener makes as you approach its maximum tensile strength.
#85575 07/18/03 02:11 PM
Once the maximum amount of Erks has been reached, the next sound is usually something that shouldn't be printed here...
#85576 07/21/03 09:04 AM
Speaking of torque specs, when installing box clamps or other items with lock rings, does anyone know the correct number of ft-lbs to apply to the screwdriver with the hammer?
#85577 08/01/03 07:03 PM
FWIW:
I just watched a Journeyman electrician retorque some lugs to well over 30 pounds-feet, with a calibrated (have the paper) pounds-inch torque wrench set to 100 lbs-in. (watched it being set by the UPS tech and verified it). Some people just don't get it.
Jim
