1 members (Scott35), 383 guests, and 13 robots.
#8348 03/19/02 08:28 PM
F
frank Offline OP
I have to remove a few pull stations for construction and was wondering if they are as easy to remove as heat sensors.There are two panels an edwards MC 250 and a MC 350 the 350 has pull-stations with evacuation and standard bells.The pull-stations are Edwards SPOW and 30 years.Thanks
#8349 03/25/02 10:46 PM
If you don't mind the system going off, they are very easy to do. Once removed( if the system is to remain online) all you have to do is wire nut the wire back accordingly.
#8350 03/26/02 07:54 PM
[This message has been edited by sparky (edited 04-29-2005).]
