Smoky?
by HotLine1 - 06/07/23 03:08 PM
Historical NEC Info
by gfretwell - 06/03/23 02:15 PM
Water heater 208 vs 240
by gfretwell - 06/02/23 06:26 PM
Help Finding Fault
by gfretwell - 05/30/23 10:05 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
1 members (HotLine1), 26 guests, and 38 robots.
#8277 03/15/02 12:45 AM
I am asked this question time and time again, just thought I would see what everyone else thinks on the topic.
When you wire/rewire my home will the wiring become obsolite or dangerous in the next 20-30 years?
When I wire I try to leave as much as possible on the circuit. Ie each room has its own lighting circuit. The receps has its own in 12ga. The reason for this is because who knows what the future will bring. I mean heck we could have air conditioned ceiling fans 10-20 years from now. (Not that a 15 amp circuit would do much for it.) But for those customers/clients who want to wire for the future. how much is enough? what would you do?
James
#8278 03/15/02 04:59 PM
Unless someone has a crystal ball I don't think that question could be accurately answered. I think the best thing you could do is wire for future expansion. Which could be allowing a chase for power and phone cable etc. to an accesable space so you can add what maybe required in the future.
#8279 03/15/02 09:32 PM
To add to the other post, help yourself out in the future by adding a few "spare/future" runs to different places, have ample breaker space in your panel[s], add a few unused stubs in walls, and so forth.
Make it so in the future you can add or revise things without tearing up too much stuff!
Your conductors if installed properly now will not have any hazards in the future.
A good example is Knob and Tube installs. The ones that have not been messed up are working fine now. Other example would be Romex installed in the late 50's / early 60's. If not damaged, it works fine.
Keep these items in mind when your planning the Electrical power and signal systems.
Scott SET
#8280 03/15/02 10:02 PM
JM,
You pose a question that I have often asked myself. I have come to the conclusion that the answer given by wirewiz and scott is about the best that could (or should) be expected. Notice the following:
1. What if your customer spends an additional $1000.00 to "wire for the future", and then circumstances force him to sell the house? The $1000.00 he spent will not increase the value of that house one dime. It might increase it to us because we are electricians, and understand that there is value there, but the average consumer would probably care less.
2. What if he never does anything extra to his house? That $1000.00 would be spent for nothing.
3. I have people tell me that they want to put their panel on the inside of their house. When I ask them why, they tell me that if a breaker trips they won't have to go outside to reset it. I respond by asking them, "how often do breakers trip?" They reply, "Not very often." Taking into consideration the clearances required in article 110, I would say that it is foolish to give up the space required to install a panel inside the house when breakers do not trip very often. JM, you know as well as I do that that space must be clear. Why give it up. It's as if they are anticipating that there will be problems with the electricity before the house is even built.
4. Making reasonable provisions for the future is fine, but "overkill" is like #3 above. How can we even predict what the next 10-20 years will have in store?
I am glad to see you ask the question. It shows that you care enough about your customers to consider their future. The other extreme is wiring to absolute minimum. That's another topic all together. "Balance Grasshopper, is the key."
Regards,
Doc
[This message has been edited by The Watt Doctor (edited 03-15-2002).]
The Watt Doctor
Altura Cogen
Channelview, TX
#8281 03/15/02 11:18 PM
I believe that our current standards in the Code are more than adequate. Of course, there is nothing wrong with over-wiring, but most of the time it is not necesary.
And of course, there are other factors to consider. Copper is pretty cheap right now. What if the price of it goes up? Then you may have to rethink installing #12 on everything and using extra circuits. And dont count on the cost of electricity staying low forever, either.
Hopefully, lighting and appliances will become more enery efficient in the next 10-20 years. That will reduce the need for extra wiring too.
Peter
#8282 03/15/02 11:27 PM
I do think, however, that provisions should be made for future technology upgrades. For instance, photo voltaic systems are becoming more and more popular. Why not run a few empty conduits up into the attic for this purpose? Dont forget about fuel cells, either. Hopefully, those will come into widespread use too.
[This message has been edited by CTwireman (edited 03-15-2002).]
Peter
#8283 03/16/02 11:22 AM
Tom Offline
I think the best you can do is make sure there are some breaker spaces left in the panel, the service is not loaded more than 60% or so and install spare raceways from the panel to the attic, basement, crawlspace, etc.
I also stick in a couple of pieces of 3/4" pvc from the basement or crawlspace to the attic and drill a few 1" holes in the top & bottom plate on an interior wall & put in pullstrings. This allows for future power or data cables to be installed. Takes about an hour & the material cost is about $5 to $10.
#8284 03/16/02 07:30 PM
I am fortunate enough to have the majority of my business as referal's. (90%) [Linked Image] Because everyone of my clients know that I am there for there intrests first not my own. I do my best to explain what I can in laymans terms. I used to be like them afraid of electric and would not even dare look at it.. Just the thought of touching a panel made me cringe. [Linked Image] But after the schooling and lots of additional training and of coarse hands on expirence, I try to share my knowledge with the customer. This is not to say I am teaching them what to do. But I am explaining what I am doing so at the end when they get my bill they arent left wondering if what I did was truly justified. I beleive an educated customer is a happy customer. A happy customer turns around and tells everyone about you.. [Linked Image]
OK a little off topic but I want to give everyone of my clients the best that there is. So when I wire I try my best to wire for the future. Especially when it comes to landscape lighting. UGH! Nothing worse then running out of feeds when lighting a yard. [Linked Image]
James
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
HotLine1
HotLine1
Brick, NJ USA
BigB 6
307,219 Are you busy
235,196 Re: Forum
219,297 Need opinion
