0 members (), 201 guests, and 38 robots.
#81678 09/06/02 08:27 PM
According to the definitions (in 680.2) of 'Permanently Installed Swimming Pool' and 'Storable Swimming Pool', what would a 4' above-ground all non-metallic pool be classified as?
It seems to depend on which one you read. ??
Bill reading the definition, "on or above ground holding water to a max depth of 42" or a pool with nonmetalic, molded polymeric walls or inflatable fabric walls regardless of dimension" I think the key word is nonmetallic here. The way I read it that is a storable pool. I would think that the definition of storable pool goes farther than the definition of permanantly installed pool by giving actual material types and calrifyng their classification. Does this make sense to anyone?
E-Man,
Look at the 'Permanent' Definition;
"and all others capable of holding water in a depth greater than 1.0 m (42 in.) ..."
Our 4' pool would fit in here as well because of it's height/depth.
I read that too Bill. Seems like a bit of contradiction with these two definitions. I wonder what the intent actually is.
cookcc
cookcc
California ,Long Beach
Trumpy 5
dsk 1
davey 1
552,972 Are you busy
427,593 Re: Forum
398,061 Need opinion
