1 members (Scott35), 475 guests, and 15 robots.
#81517 08/24/02 01:10 PM
triple Offline OP
I am uncertain as to when this section can be sited as a reason for utilizing a breaker with a rating above the ampacity of the conductors being protected. Say, for instance, the ampacity (after all derating) of a set of service conductors is 380A. Since, according to 240.6(A), standard breaker size jumps from 350 to 400A, can the conductors with an ampacity of 380A feed a 400A service?
#81518 08/24/02 01:19 PM
The 380 amp conductors may be protected by a 400 amp over current device but the maximum calculated load on these conductors can not exceed 380 amps.
Curt Swartz
#81519 08/29/02 11:24 AM
For service over current protection and conductor coordination you must look in services because the rules are diferent.
230.90.A
This does not allow for selection of the next higher size of over current protection.
tom
#81520 08/29/02 04:32 PM
Tom Offline
Rounding up to the next standard size is permitted. Take a look at 230.90(A) exception 2 and if you have the handbook, see the commentary following the exception.
