ShoutChat Box
Lock-down Thread
by gfretwell - 05/08/21 01:39 PM
Do You Travel?
by gfretwell - 05/07/21 07:44 PM
Unemployment Fraud
by gfretwell - 05/07/21 07:28 PM
How's all our Non-US folks doing?
by grich - 05/07/21 06:04 PM
Where is Everyone?
by grich - 05/06/21 05:49 PM
2020 - 2021 Winter Project
Garden 2021
0 registered members (), 16 guests, and 17 spiders.
Insulation Resistance #81416 08/12/02 02:48 PM
Joe Tedesco Offline OP
From Norm Koon:
I have a question concerning cables that are approximately 45 years old.
The insulation resistance test read as follows:
Air Temp 82 deg F
One Minute Megohm readings Ph A 1220 Ph B 2540 Ph C 484
Ten Minute Megohm readings Ph A 1470 Ph B 4100 Ph C 510
PI Index Ph A 1.11 Ph B 1.61 Ph C 1.05
Given this test data, would it be advisable to reuse these cables?
These cables are partly running underground, inside a basement and outdoors, so
an accurate temperature reading was not used. The temperature is only the outside
air temperature. Also they are still hooked up to the primary bushings of the transformer.
So they are not true readings of the cables. I was wondering if the disparity of the readings could be due to leakage on the transformer bushings. The test voltage was 2500 vdc. The system voltage is 6900 volts ac.
2017 / 2014 NEC & Related Books and Study Guides
Re: Insulation Resistance #81417 08/12/02 04:21 PM
Bjarney Offline
"...still hooked up to the primary" should make individual readings meaningless, unless I misinterpreted something.
Re: Insulation Resistance #81418 08/12/02 04:34 PM
Bob Offline
Norm
The 2500 volt DC test does not provide an adequate check of the insulation integrity.
Is the cable in use now? I would want to Hi Pot test the cable. New 15 kv cable is tested at about 60 kv but that is not what you want on cable this old. Check with the mfg annd see if they can give you a value to test the cable.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
sparky66wv
sparky66wv
West Virginia
Show All Member Profiles
Trumpy 15
Admin 8
278,691 Are you busy
211,890 Re: Forum
198,941 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
