Al Hildenbrand - Minneapolis - obituary
by bcpappas - 02/02/23 08:01 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 24 guests, and 20 robots.
#81195 07/19/02 06:46 AM
sparky Offline OP
Does anyone here know of a quadriplex, with 4 insulated conductors, listed for an OH run ?
2020 NEC & Related Reference & Study Guides
Pass Your Exam the FIRST TIME with these Exam Prep Combos:
>> Master Electrician Exam Prep     >> JourneyMan Electrician Exam Prep
#81196 07/19/02 03:46 PM
Sparky:
It's a little late to place a call, but I believe our main supply house has quadplex
on a bare messinger, al only, largest is #1??
HotLine1
#81197 07/19/02 04:09 PM
sparky Offline OP
thanks John.
yep i know i can get it with a bare 4th ASCR etc, i was wondering about all 4 insulated conductors.....
#81198 07/19/02 04:58 PM
99NEC Article 321 — Messenger Supported Wiring
321-1. …exposed wiring… to support insulated conductors by…: (2) A messenger with a field-installed lashing material for conductor support.
Not aware of 4-insulated-conductor construction, but based on referenced text, it may be possible to make or modify existing product [like original ‘quadruplex.’] Custom made in suitable quantities through a wire house may be cost effective.
#81199 07/20/02 05:38 AM
sparky Offline OP
hmmmm, ok thanks, BTW,we have a Belden co up here, probably a good place to ask.
The concern was to address an overhead feeder to a poolhouse, for a pool. As i've talked the customer into a UG feeder this now becomes hypothetical, yet somewaht a 680 qaugmire.....
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
renosteinke
renosteinke
Blue Collar Country
BigB 4
triple 3
303,003 Are you busy
232,028 Re: Forum
216,769 Need opinion
