276
15
I have a situation where a wall mounted oven is mounted in a base cabinet. The original installer mounted a receptacle behind the oven. But, I don't believe this is accessible as the oven would have to be unscrewed & removed to gain access. They also installed the 120 volt receptacle for the gas cooktop ignition in the same area. I believe that I have to relocate the 120 receptacle and install the j-box for the new hard-wired oven in the back of an adjacent base cabinet, but if I don't have to do so, I would like to leave the wiring intact in order to minimize the cost to these senior citizens. Any thoughts?
The oven setup is ok. The j box can be in the same cabinet as the oven. As for the cooktop I think this is fine. Maybe it would be better if the 120 receptacle was easier accesed but I cant find a code reference that says it must be.
scott, You think the j-box & receptacle would seem to be "accessible" even though the oven would need to be removed (dismounted) to gain access? I guess that since no disturbance of the building materials would be required, this may be considered accessible by definition, but I'm not too sure.
the only thing ( other than accessable definitions that i can find...) (3) Wall-Mounted Ovens and Counter-Mounted Cooking Units. Wall-mounted ovens and counter-mounted cooking units complete with provisions for mounting and for making electrical connections shall be permitted to be permanently connected or, only for ease in servicing or for installation, cord-and-plug connected. A separable connector or a plug and receptacle combination in the supply line to an oven or cooking unit shall be approved for the temperature of the space in which it is located.
I read that also. I do kitchens everyday and have yet to have an inspector cite me on this type of setup. In a new installation I put the j box in the cabinet above the oven if at all possible. This allows the kitchen guys to install the oven and I dont have to move it to make the connections. Also the only reason you would need to get to the j box would be to disconnect the oven to remove it.
