ShoutChat Box
Lock-down Thread
by Bill Addiss - 02/26/21 08:40 PM
Northern Tool Recalls Powerhorse Generators
by Admin - 02/25/21 09:49 PM
You will never guess
by gfretwell - 02/25/21 07:48 PM
New tool
by SMOKEYBOB - 02/15/21 04:59 PM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 15 guests, and 17 spiders.
Grounding Gutters/Downspouts #78903 11/06/01 09:01 PM
WiCeltic Offline OP
Art 426, Exposed deicing and snow-melting equipment there is nothing on how or if the gutters/downspouts on a residential house should be grounded. The cable is listed and the manufacturer says to see instructions, which we couldn't find any mention of how to ground the gutters. Going to call manufacture tomorrow, but wondered if any northern electricians had so insight on this. Thanks again.
2017 / 2014 NEC & Related Books and Study Guides
Re: Grounding Gutters/Downspouts #78904 11/07/01 10:58 AM
resqcapt19 Offline
There should be no need to ground the gutters and downspouts because 426-27 requires the heating cable to have an conductive grounded sheath and 426-28 requires ground fault protection of equipment for the heat cable. These provisions should eliminate any need to ground the gutters and downspouts.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
NickD
NickD
Amish Country, PA
Show All Member Profiles
275,414 Are you busy
209,306 Re: Forum
196,596 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
