0 members (), 148 guests, and 10 robots.
#76039 11/03/00 12:29 PM
I have a new installation where the MC ran hot water heat pipes less than 2 inches away from the side of an electrical panel. The heating line contains an automatic air bleeder valve near the top of the panel. The lines do not enter the dedicated equipment space as defined in 110-26.f. The outlet of the bleeder valve points away from the panel and under normal operation, should not cause a water problem. I can not find anything in the code that prohibits this installation. I would like to have the MC move his lines, but I need back-up from the code. Am I missing something?
Workgear for Electricians
Depending upon the width of your panelboard you may be able to use 110.26(a)(2)
