Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
AFDD's coming to the UK
by Texas_Ranger - 01/17/23 07:22 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
1 members (Scott35), 17 guests, and 22 robots.
Page 3 of 3 1 2 3
I've done it. It was cord and plug connected and plugged into a GFCI receptacle, since it was in the bathroom cabinet. It's up to the homeowner to not burn their house down doing something I would call "stupid." [Linked Image]
It looked pretty sweet when I was done, despite the fancy custom drawer being almost exactly the same height as the receptacle coverplate was wide.
-George
e57 Offline OP
Surface mounted panels are ouside the wall... Surface mounted conduit too...
The line dividing here is the receptical... Otherwise it is Premises Wiring...
Premises Wiring (System). That interior and exterior wiring, including power, lighting, control, and signal circuit wiring together with all their associated hardware, fittings, and wiring devices, both permanently and temporarily installed, that extends from the service point or source of power, such as a battery, a solar photovoltaic system, or a generator, transformer, or converter windings, to the outlet(s). Such wiring does not include wiring internal to appliances, luminaires (fixtures), motors, controllers, motor control centers, and similar equipment.
And right up to the device in the drawer mounted box is a Branch Circuit. If there were a receptical at the wall, it would be utilization equipment....
I was referring to the picture not wiring in general.
Page 3 of 3 1 2 3
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Shinnston, WV USA
BigB 9
triple 3
302,542 Are you busy
231,900 Re: Forum
216,535 Need opinion
