Does a metal lightpost that is 3 feet from a lake have to gfi protected? Also low voltage lighting on a dock can the wire just be stapled underneath (12v). Have not done to much work by bodies of water. Does the transformer have to be 10 feet away like a pool? thanks
If the local dockside resturants, that I assume get inspected, is any guide, 120v "twinkle" lights stapled to the rail are OK if they are on a GFCI. Rope light is the upgrade.
