Photos of the Week:
Meter vs Bricklayer
Meter vs Bricklayer
Random Gallery Image:
0 members (), 19 guests, and 24 robots.
#65277 05/01/06 01:21 PM
SvenNYC Offline OP
Why are they called that?
I've usually seen the term applied to the square or cylindrical surface-mount switches.
#65278 05/01/06 09:21 PM
F
the tumbler switch can be found in motor or industrail control panel it will look like a handle outside of the door panel but inside will look like " open " drum switch with large number of concats.
this is very common on older control panels but newer one are controled by plc system but however for some still used the tumbler switch on it currentally. [ not too widespread ]
the last time i did see tumbler switch was in power control panel [ for multi generator units ] it have 12 lead connected to the " drum " switch
hope it help you with this
Merci, Marc
#65279 05/01/06 11:23 PM
They still use Furnas 58 drum switches on boat hoist motors.
#65280 05/01/06 11:56 PM
SvenNYC Offline OP
OK, I'm confused.
I just visited Appleton's website and saw what THEY call a "tumbler switch" (an enclosed heavy-duty switch with a metal handle).
What I've commonly seen called a tumbler switch is usually one of these:
[Linked Image from kopez.com.ph]
or this:
[Linked Image from iseao.co.kr]
Yeah. I know they misspelled "tumbler". [Linked Image]
[This message has been edited by SvenNYC (edited 05-02-2006).]
#65281 05/02/06 03:34 AM
Because of the need to break contacts fast enough to prevent them wearing from arc damage, 'tumblers' were developed from the original crude knife switches.
The 'tumbler' is a mechanism which on pressing the switch lever places the contacts under an increasing spring load, and is arranged so that when sufficient force exists, at some point in the stroke, the contact set suddenly 'tumbles' rapidly into the closed or open position, reducing arcing. Early mechanisms were clunky and heavily preloaded to ensure a crisp action. Modern switches have been developed in which the forces are much lower due to smaller and lighter moving parts, precision mouldings and superior plastics, but it's the same principle.
#65282 05/02/06 07:07 AM
Here's a British tumbler switch, 1940s/early 1950s style (Britmac "Little Briton" rated 250V 5A AC/DC). Note the spring linkage between the operating handle and the contacts below:
Starting from the "on" position, thus:
Moving the handle upwards toward "off" moves the top of the tumbler assembly downward (foreground of photo), but all it does initially is to start tensioning the spring:
Handle moved over the greater part of its travel, but contacts still firmly closed:
Almost there now, note the position of the spring with the top of the tumbler almost at the "point of no return":
Until finally, on the very last portion of the travel the spring snaps the contacts open quickly:
[This message has been edited by pauluk (edited 05-02-2006).]
#65283 05/02/06 08:51 AM
SvenNYC Offline OP
AHHHH!!!!
Thanks Paul & Alan.
Fascinating. So then the term applies to any standard toggle or rocker switch, not just the surface mount types. [Linked Image]
#65284 05/02/06 12:21 PM
Are we talking about "Snap switches"?
#65285 05/02/06 07:37 PM
So.......ball-bat switch, toggle switch, snap switch, tumbler switch, they are all the same switch, different name.
Earl
#65286 05/03/06 05:19 AM
On some worn switches similar to the one pictured it can even happen you move the handle all the way and it takes a second or two until the tumbler moves... about the only type of failure I've ever seen with that type of switch.
Tools for Electricians
Vlado
Vlado
Croatia
Admin 3
CSS 1
366,493 Are you busy
289,473 Re: Forum
268,084 Need opinion
