0 members (), 220 guests, and 12 robots.
V
IMHO,,,plastic boxes,,nope wont use them
Patrick
I can't figure out how to get EMT into them.
Dave
Will never see them in New York City either.
We use metal boxes and types AC or MC cable.
Metal boxes and EMT here in Chicago.
Ghost307
Mahlere,
You are correct, I do not compete against this company. They only do tract homes for national builders, we don't do tract homes.
Tiger,
EMT will fit fine if you unibit the back out and put the connector in.
The manufacturer has a free challenge kit available to try out their system(free boxes, but no devices). http://www.cheetahspeed.com/cheetah_electrician_challenge.html
Standard devices can replace their custom ones. Their devices will unscrew from the push-in blocks that attach them to the boxes and allow conventional devices to be screwed to the blocks. http://www.cheetahspeed.com/cheetah_electrici
an_faq.html
steve
[This message has been edited by stamcon (edited 04-16-2006).]
Steve
e57 Offline
Cant remember who makes 'em, but there is a box that can use any device, (no special anchors) and you can just push the device screw in. They have a spring metal clip in the hole that allows the screw to just be pushed back across the threads. They work well.... And nothing too specialized, so that you're stuck using specific devices. Wouldn't mind seeing those on metal rings! (Especially for the ones that didn't make it through the threading proccess before I installed it.)
As for the wall-plates, I can see a big problem with how these are set up. On uneven surfaces, where some fine adjustment will be nessesary to make the plate look like it it is even, (know what I mean?)you would have to pry the plate off several times in order to do it. Where as other screwless plates you can make those adjustments before the final plate goes on. Nice idea though....
The plumber was there today and the sheetrock will be going up soon. The devices are on our truck. Will inform all of you how the whole thing came out. The password will be ( IF IT WORKS)
e57. pass & seymour or slater is who you are looking for.
