Shout Box
Tray cable?
by davistrembley. 02/22/19 07:53 AM
Light activation in closet by a broken connection?
by geoff in UK. 02/19/19 01:35 PM
AFDD's coming to the UK
by Texas_Ranger. 02/18/19 02:04 PM
Israel
by Texas_Ranger. 02/18/19 02:01 PM
What is this for?
Plug terminals
1 registered members (Scott35), 11 guests, and 10 spiders.
Underground Aquarium Tank - Panel Install #62426
02/15/06 02:41 PM
02/15/06 02:41 PM
aldav53  Offline OP
Chandler, AZ USA
Installing an outdoor panel for an indoor underground aquarium tank which will have 2 or 3 pump motors, probably similar to pool pump motors. A main 200 amp panel feeds a 125 amp sub-panel panel, then I will come off the 125a sub-panel with a.. probably 60 amp outdoor panel for the aquarium tank, the ones they use on pools (tan colored) for pump motors etc., should work ok. I think they hold about 8 circuits. Or is there a better type to use?. Should be ok to run a sub-panel off another sub-panel, correct?
Re: Underground Aquarium Tank - Panel Install #62427
02/15/06 08:27 PM
02/15/06 08:27 PM
HotLine1  Offline
Brick, NJ USA
Aldav53:
As long as the 'loads' are within the capacity of the OCP's you could do sub-panels to the 10th power(?) Check your connected loads, and perhaps do a quick load calc.
Any 3R panel would be acceptable outside, as long as it;s properly sized. (# of available circuits; ampacity of main lugs)
Hopefully, this is the type answers you're looking for.
Re: Underground Aquarium Tank - Panel Install #62428
02/16/06 12:44 PM
02/16/06 12:44 PM
aldav53  Offline OP
Chandler, AZ USA
The home has a 400a service fed with 2 mains split into 2 - 200a panels. Each 200a panel has a 125a off it. I'm using 1 of the 125a sub-panels. But your right I'll have to do a quick load calc.
I've seen a lot of those (tan colored) sub-panels, they usually have a built in GFI recept and reciever for a remote pool light control inside the panel. But guess I don't need that. A regular outdoor 8 or 12 circuit panel should work, fed with #6's probably, as long as it doesn't exceed the 125a panel load.
Re: Underground Aquarium Tank - Panel Install #62429
02/16/06 12:49 PM
02/16/06 12:49 PM
aldav53  Offline OP
Chandler, AZ USA
Also, pool pump motors aren't fed with a GFI breaker, but spa's are. Why is that? If I use a GFI breaker to feed the aquarium pump motors, not sure if thats required?
I'll post this in the code section too.
Re: Underground Aquarium Tank - Panel Install #62430
02/17/06 10:38 AM
02/17/06 10:38 AM
aldav53  Offline OP
Chandler, AZ USA
The load on this aquarium wil have 1 - 18a heater, 1 - 18a chiller, (not used at the same time), a 10a pump, and 3 - 4amp motors for other stuff.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
NickD
NickD
Amish Country, PA
Show All Member Profiles
Admin 9
253,302 Are you busy
189,916 Re: Forum
179,633 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.017s Queries: 14 (0.003s) Memory: 0.9681 MB (Peak: 1.1079 MB) Zlib enabled. Server Time: 2019-02-22 18:44:33 UTC
