373
12
Has anyone had a residential rough wire inspection without the service panels installed? Are the panels necessary?
Never heard of a rough without having the panels in. We didnt install breakers for the rough but all the wires were in the panel for it.
Posts: 7,381 Likes: 7
Redsy: We do 'rough' wire, either with or without the service being installed.
Yes, It can be done . Here you can have a rough wire inspection and not have service completed. You will not get the service released to the poco until it is completed and inspected. I have always had the service and rough in at the same time.
Thanks,Guys! I usually do the service first, or at the asme time, but circumstances interfere this time, and I want to send out a bill for the rough.
Hotline,
It is in Edgewater Park, near Willingboro. I'm a little anxious about my first NJ inspection. You guys are supposedly pretty thorough, and I didn't want to overlook some thing stupid.
Redsy overlook something?
Not a chance....
Dnk..
Redsy: Na, you won't do nothing stupid! I don't know anyone down that way. But...the UCC and NEC is statewide, so on that note you should be fine.
As I said, normally, rough wire can be done without the service, service can be done without rough, but you need a "load" to keep the POCO happy.
EC's in the twp that I work in usually do rough & service, unless it's $$$, or the siding isn't up.
Here there are service inspections, rough inspections, and final inspections. No need for the panel to be installed for anything other than the service inspection.
Scott: You can get a final without a panel????
HA! HA! Just joking around; you opened the door, so....
