Countertop Receptacles
by HotLine1 - 05/18/23 12:40 PM
Windows 10, who's upgraded?
by LindaParker - 05/15/23 04:29 AM
We can all breathe easy....
by gfretwell - 05/11/23 01:00 PM
What's your Hobby?
by gfretwell - 05/11/23 12:57 PM
Your favourite food?
by renosteinke - 05/10/23 09:28 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 60 guests, and 17 robots.
#6129 12/23/01 08:45 PM
ccmann Offline OP
Is wrighting on a diconnect with a permanent marker a legal way to identify the disconnect.
#6130 12/23/01 10:19 PM
ccmann,
That's what the inspectors think out my way (Sacramento, California). That's the only thing they'll accept for labelling breaker spaces in panels. I can't argue, just about any stick-on label will eventually fall off.
I carry a bottle of some stuff called "contractors cleaner", a citrus-based solvent. A little on a rag will take off the remnants of a paper label if you're re-labelling a breaker space, or will remove the magic marker if you goofed and have to change a label.
Cliff
#6131 12/24/01 12:07 AM
2002 has addressed this, in Article 110.22, but left it unclear of what is considered sufficient durability, Basicaly left judgement up to the (AHJ). I presonally carry a label maker that in my opinion looks more perfessional, than a marker. I have seen marker indentification look perfessional, than I have seen them also look like caveman art. Some guys even use the old press lettering (one click at a time) device. Works OK. The ones now I'm seeing that I like is printed labels with a clear sticky back envelope stuck to the disconnect, and you can make them from your own PC. Then change them latter if need be.
[This message has been edited by aphares (edited 12-23-2001).]
#6132 12/24/01 08:24 AM
Outdoors, many inspectors in this area (SoCA) won't accept felt pen as a permanent marking. It virtually disappears after some weathering.
Instead, they'll accept the use of the "paint pen", which applies enamel, and is just as easy to use as the felt pen.
Many labels won't withstand the test of time either, the adhesive loses its grip, and they fall off. The newer style of labelmaker is better for this, but the ink doesn't stand up to UV very well; it fades fairly quickly.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
MarkC10
MarkC10
CA, Inland Empire
Trumpy 11
306,970 Are you busy
234,859 Re: Forum
219,145 Need opinion
