Shout Box
AFDD's coming to the UK
by Texas_Ranger. 02/18/19 02:04 PM
Israel
by Texas_Ranger. 02/18/19 02:01 PM
250.104
by gfretwell. 02/16/19 01:08 PM
PurpleAir Recalls Power Supply Units
by Admin. 02/14/19 08:43 PM
Utility Company Programs
by katty81. 02/14/19 11:11 AM
What is this for?
Plug terminals
1 registered members (gfretwell), 10 guests, and 28 spiders.
Help to Indentfy GFCI Part #60428
01/02/06 04:36 PM
01/02/06 04:36 PM
wendel  Offline OP
I have a GFCI part I need to replace but it may now be obsolete. It was located in a 120 volt shower recessed light fixture. The GFI device is cylindrical, 3/4" in diameter, 2.5" long with cooling holes on one side. It plugs into the junction box knock-out of the recessed light fixture where it's wired into the light circuit. The leads are black, white and blue in color. I think this was installed around 1989 when the house was built. Can anyone tell me if these devices are still available and what their designation is. Thanks.
Re: Help to Indentfy GFCI Part #60429
01/02/06 04:39 PM
01/02/06 04:39 PM
Electricmanscott  Offline
Holden, MA USA
I have never heard of such an item as a GFCI part. It is most likely a thermal cutout sensor. You will need the name of the manufacturer of the fixture.
Re: Help to Indentfy GFCI Part #60430
01/02/06 05:38 PM
01/02/06 05:38 PM
LK  Offline
New Jersey
wendel,
I notice occupation, is missing in your profile, It would be careless on our part to give advice on this issue, That device can be anything from a low voltage relay to an X10 type of device, if you are not sure what you have, it may be best to get an electrician to investigate.
Re: Help to Indentfy GFCI Part #60431
01/02/06 08:37 PM
01/02/06 08:37 PM
electure  Offline
Fullerton, CA USA
LK is right. Without more information it would be foolhardy and irresponsible for us to give you an answer.
What leads you to believe this is a GFCI device? Is there a label?
Re: Help to Indentfy GFCI Part #60432
01/02/06 08:45 PM
01/02/06 08:45 PM
gfretwell  Online Content
Estero,Fl,usa
If it doesn't have a test button it isn't a GFCI device. I am betting for low voltage relay.
Re: Help to Indentfy GFCI Part #60433
01/02/06 08:51 PM
01/02/06 08:51 PM
NORCAL  Offline
Perhaps a thermal protector?
Re: Help to Indentfy GFCI Part #60434
01/02/06 09:04 PM
01/02/06 09:04 PM
wendel  Offline OP
Thank you for your help. I'm a mechanical engineer by education. I believe it's definitely a thermal protector device since all similar recessed lights are also equipted with this device. My GFI inclination was due to the light's location in the shower and the fact I have worked with recessed lighting that wasn't equipted with those safety devices. The device is malfunctioning and I'm going to replace it. Unfortunately there's no manufacturer's name, only various catalog numbers. I'm sure the local electrical supply house will be able to help me. Thank you again.
Re: Help to Indentfy GFCI Part #60435
01/02/06 11:00 PM
01/02/06 11:00 PM
renosteinke  Offline
Blue Collar Country
Why fuss over a cheap tin can? Just replace the whole blessed thing.
Re: Help to Indentfy GFCI Part #60436
01/03/06 08:36 AM
01/03/06 08:36 AM
Holden, MA USA
It is genneraly far easier to replace the thermal switch than to replace the can. Especially if it was a new construction can.
Re: Help to Indentfy GFCI Part #60437
01/03/06 05:21 PM
01/03/06 05:21 PM
wa2ise  Offline
Oradell NJ USA
Sure you're not using a too high wattage light bulb in it? Or maybe there's too much insulation in the ceiling touching it and allowing it to get too hot.
If one will physically fit, a compact florescent bulb may be a solution. Less heat for the same light output.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Show All Member Profiles
Admin 7
253,245 Are you busy
189,886 Re: Forum
179,597 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.032s Queries: 14 (0.005s) Memory: 1.0095 MB (Peak: 1.1840 MB) Zlib enabled. Server Time: 2019-02-19 06:48:15 UTC
