Shout Box
Tray cable?
by davistrembley. 02/22/19 07:53 AM
Light activation in closet by a broken connection?
by geoff in UK. 02/19/19 01:35 PM
AFDD's coming to the UK
by Texas_Ranger. 02/18/19 02:04 PM
Israel
by Texas_Ranger. 02/18/19 02:01 PM
What is this for?
Plug terminals
1 registered members (Scott35), 7 guests, and 20 spiders.
Fishing Flex #59412
12/04/05 12:26 PM
12/04/05 12:26 PM
Wireless  Offline OP
Los Angeles CA USA
Does Flex need to be strapped when fished through a drop ceiling?
Re: Fishing Flex #59413
12/04/05 01:26 PM
12/04/05 01:26 PM
e57  Offline
S.F.,CA USA
348.30 Securing and Supporting.(A) Securely Fastened. FMC shall be securely fastened in place by an approved means within 300 mm (12 in.) of each box, cabinet, conduit body, or other conduit termination and shall be supported and secured at intervals not to exceed 1.4 m (41/2 ft).
Exception No. 1: Where FMC is fished.
Dropped ceiling with removable panels just means laziness...
Re: Fishing Flex #59414
12/04/05 03:00 PM
12/04/05 03:00 PM
Wireless  Offline OP
Los Angeles CA USA
Laziness? Having to open every tile on a 100+' run is alot more then opening 3 or 4.
Re: Fishing Flex #59415
12/04/05 03:41 PM
12/04/05 03:41 PM
iwire  Offline
North Attleboro, MA USA
I do not believe for a minute that the inspector will agree that a suspended ceiling run is 'fished'.
IMO you will have to support the FMC off the ceiling.
Re: Fishing Flex #59416
12/04/05 03:42 PM
12/04/05 03:42 PM
Cow  Offline
Hermiston, OR
I agree with e57.
To put things in perspective.
100' run- 4' tiles= 25 tiles. Open every other one to strap means 12-13 tiles opened.
If tiles are 2' long then you open every 2-3 tiles, 15-25 opened. Whats the big deal. Leaving flex laying on tiles is lame. It's bad enough when the LV guys do it.
Re: Fishing Flex #59417
12/04/05 04:21 PM
12/04/05 04:21 PM
A-Line  Offline
Utah, USA
I believe the NEC now requires even low voltage cables to be supported in dropped ceilings. I don't think laying the cables accross the grid is acceptable anymore.
[This message has been edited by A-Line (edited 12-04-2005).]
Re: Fishing Flex #59418
12/04/05 05:58 PM
12/04/05 05:58 PM
Wireless  Offline OP
Los Angeles CA USA
Every 4.5' would be every tile. It was not fished just straight across the tile but over whatever was available to support it without getting in there.
[This message has been edited by Wireless (edited 12-04-2005).]
Re: Fishing Flex #59419
12/04/05 06:57 PM
12/04/05 06:57 PM
LK  Offline
New Jersey
We just went thru this with a store, the LV guy fished the camera cables, no permit, just one problem the fire, and construction offical were in the store at the time, finally they caught a live one, the store owner was not very happy, paying to have it done right.
Re: Fishing Flex #59420
12/04/05 08:23 PM
12/04/05 08:23 PM
hbiss  Offline
Hawthorne, NY USA
Probably a better question is why are you using 100 feet of greenfield in one run?
-Hal
Re: Fishing Flex #59421
12/04/05 08:31 PM
12/04/05 08:31 PM
ShockMe77  Offline
Rahway, New Jersey
And if it was piped in say E.M.T. it would only have to be supported every 10'. I have to agree with everyone else here, do it right the first time and support the flex to what the code calls for. Good luck.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Alan Belson
Alan Belson
Mayenne N. France
Show All Member Profiles
Admin 9
andey 3
253,316 Are you busy
189,923 Re: Forum
179,647 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.025s Queries: 15 (0.004s) Memory: 1.0221 MB (Peak: 1.1979 MB) Zlib enabled. Server Time: 2019-02-23 19:06:01 UTC
