Shout Box
LED retrofit flickers
by rmiell. 01/18/19 08:49 PM
Israel
by Texas_Ranger. 01/14/19 07:12 AM
Free Code class in Maryland 1/16/2019
by Admin. 01/12/19 05:43 PM
Calling all Non-US members!! (Non-US only)
by RODALCO. 01/12/19 02:37 AM
sec cable code conflict
by jake2018. 01/11/19 07:36 PM
What is this for?
Plug terminals
0 registered members (), 12 guests, and 10 spiders.
Wasps in Service Mast #59224
11/30/05 11:05 AM
11/30/05 11:05 AM
demo_guy  Offline OP
I had wasps in the service mast. What can I use to seal off the openings where the wire enters? Caulk? If so, any particulare recommendations?
Re: Wasps in Service Mast #59225
11/30/05 02:29 PM
11/30/05 02:29 PM
Branch  Offline
West Alexandria, Ohio, Preble
Try Duct Seal.
Re: Wasps in Service Mast #59226
11/30/05 02:35 PM
11/30/05 02:35 PM
Steve Miller  Offline
Bruceton Mills, WV
Fire foam works well, and it won't fall out as the weather changes.
Re: Wasps in Service Mast #59227
11/30/05 07:16 PM
11/30/05 07:16 PM
LK  Offline
New Jersey
Steve,
Some of the fire foam products, becomes conductive when subject to moisture, i would be careful to check with the manufacture before using this for a seal, also the foam product may react with the insulation.
[This message has been edited by LK (edited 11-30-2005).]
Re: Wasps in Service Mast #59228
11/30/05 07:49 PM
11/30/05 07:49 PM
e57  Offline
S.F.,CA USA
ditto on duct seal putty.
Re: Wasps in Service Mast #59229
11/30/05 07:54 PM
11/30/05 07:54 PM
V
vlad_tepish  Offline
Delavan,Wis,USA
can you use the same clay stuff that is used to fill the connector in a meter socket?
Patrick
Re: Wasps in Service Mast #59230
11/30/05 08:31 PM
11/30/05 08:31 PM
earlydean  Offline
Griswold, CT, USA
That "clay stuff" is duct seal (also known as monkey-poo).
I use silicon caulking to fill the weatherhead.
Earl
Re: Wasps in Service Mast #59231
11/30/05 09:15 PM
11/30/05 09:15 PM
Elviscat  Offline
Seattle Washington USA
I'd also go with silicone
Re: Wasps in Service Mast #59232
11/30/05 09:37 PM
11/30/05 09:37 PM
JoeTestingEngr  Offline
Chicago, Il.
I also think that Duct Seal would work fine. This reminds me of another sealer question... Why do they refer to the material that you pour into a seal off to harden as, "Chico"?
Joe
Re: Wasps in Service Mast #59233
11/30/05 09:47 PM
11/30/05 09:47 PM
NJwirenut  Offline
Bergen County, NJ
A contraction of "Crouse-Hinds Co.", the original manufacturer.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
HCE727
HCE727
Delaware County, PA, USA
Show All Member Profiles
Trumpy 4
BigB 3
252,787 Are you busy
189,594 Re: Forum
179,262 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.023s Queries: 15 (0.004s) Memory: 1.0220 MB (Peak: 1.1981 MB) Zlib enabled. Server Time: 2019-01-21 11:45:53 UTC
