Shout Box
New fan motor for Panasonic
by HotLine1. 06/25/19 03:53 PM
Burning out of return(white) side of 120volt rec
by crselectric. 06/14/19 02:15 AM
Video door bell causing chime activation of coil
by JoeTestingEngr. 06/13/19 12:43 PM
Troubleshooting Voltage Drop Across Relay
by gfretwell. 06/09/19 11:49 AM
Apple Recalls Three-Prong Wall Plug Adapters
by Admin. 06/05/19 09:06 PM
What is this for?
Plug terminals
0 registered members (), 4 guests, and 7 spiders.
TDR doc's #58095
10/29/05 07:28 PM
10/29/05 07:28 PM
magoo66  Offline OP
Tillamook, Oregon
Taking a stab in the dark here.....Does anyone have a set of instructions for a Potter Brumfield programable time delay relay (model CNS-35-72) 8 pin, 4 function, 7 dip switches & a time dial on the front. Looks like a dpdt timer. More specifically, I just need to know what its supposed to do in "operate" mode.
Re: TDR doc's #58096
10/29/05 09:26 PM
10/29/05 09:26 PM
Redsy  Offline
Bucks County PA
Maybe this will help---
http://relays.tycoelectronics.com/datasheets/CNS_DS.pdf
or
http://www.jameco.com/webapp/wcs/st...amp;catalogId=10001&productId=497352
[This message has been edited by Redsy (edited 10-29-2005).]
Re: TDR doc's #58097
10/30/05 10:59 AM
10/30/05 10:59 AM
magoo66  Offline OP
Tillamook, Oregon
Your my hero! Thanks Redsy!
Re: TDR doc's #58098
10/30/05 01:11 PM
10/30/05 01:11 PM
Redsy  Offline
Bucks County PA
Awww, shucks! magoo
Glad to be of help.
BTW,
There's lots of help at this site.
[This message has been edited by Redsy (edited 10-30-2005).]
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
SafetyWired
SafetyWired
Pa, USA
Show All Member Profiles
Admin 2
255,892 Are you busy
191,869 Re: Forum
181,634 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.019s Queries: 14 (0.004s) Memory: 0.9579 MB (Peak: 1.0897 MB) Zlib enabled. Server Time: 2019-06-27 12:45:58 UTC
