Shout Box
Light activation in closet by a broken connection?
by geoff in UK. 02/19/19 01:35 PM
AFDD's coming to the UK
by Texas_Ranger. 02/18/19 02:04 PM
Israel
by Texas_Ranger. 02/18/19 02:01 PM
250.104
by gfretwell. 02/16/19 01:08 PM
What is this for?
Plug terminals
0 registered members (), 9 guests, and 10 spiders.
choke on this #57575
10/17/05 12:24 PM
10/17/05 12:24 PM
lamplighter  Offline OP
Clawson,Michigan,USA
I still get amuzed by the number of electricians I meet on the job that don't realize you can't run seperate phases to the same three phase load in seperate conduits.
I've had to explain the concept of building a "choke" to more guys than I can shake a stick at.
It's almost as bad as the concept of splicing copper to aluminum in a split-bolt without the divider.
Anyone else have anything to add about this?
Re: choke on this #57576
10/17/05 02:04 PM
10/17/05 02:04 PM
Roger  Offline
N.C.
Lamplighter, actually you can do this if you are using non-ferrous wiring methods and the conditions of 300.20(B) are met.
Roger
Re: choke on this #57577
10/17/05 02:12 PM
10/17/05 02:12 PM
I wasn't aware of that but, I've never been in a position where that would come into play either.
I have seen the effects of trying to do it in rigid metal conduit and it wasn't pretty.
Re: choke on this #57578
10/17/05 02:57 PM
10/17/05 02:57 PM
jw electric  Offline
Asheboro, NC
There is nothing wrong in learning something new, we all do this from time to time. With me the times in between are real short.
One of the hardest things that I had to learn when starting out as a green horn was just where I was at.
It seemed that I was never just where I was supposed to be and was getting yelled at due to this fact.
Well one day I just ask the boss, “Just where am I supposed to be?”
He answered me with this.
If you are not here and you are not there then you have to be somewhere else. Now get over yonder where you are supposed to be. That was thirty seven years ago and the truth be know, I am still lost.
[Linked Image] [Linked Image] [Linked Image]
Mike
Re: choke on this #57579
10/17/05 03:55 PM
10/17/05 03:55 PM
iwire  Offline
North Attleboro, MA USA
The company I work for recently repaired a job that the feeders for large RTUs where run in an isolated phase fashion. From the guys there they said it was quite an impressive meltdown.
A large underground service run in PVC is not unusual in my area.
Re: choke on this #57580
10/17/05 08:18 PM
10/17/05 08:18 PM
mxslick  Offline
Atomic City, ID USA
Any chance they took some pics? [Linked Image]
Stupid should be painful.
Re: choke on this #57581
10/17/05 09:58 PM
10/17/05 09:58 PM
One of the best melt downs I've ever seen was in a holiday in that we had as a customer.
The maintanance man for the hotel was supposedly going to tighten the lugs on the main, he threw the switch to "off", opened the door, and stuck his bare metal allen wrenck into the lug.
The mechanism supposedly allowed him to open the door without actually shutting down the power.( most likely he used his screwdriver to trip the latch and hadn't really shut it down.)
The lugs were hot, he took a 480v hit, dropped the wrench into the gear and ended up blowing a 3'x5' hole in the F.P.&L. vault wall.
We showed up and overnighted a new switch in from Alabama or someplace. striped the old out, installed new and got the 400 unit hotel back on line in 36 hours.
Damn I was tired!
The maintanance guy survived but,last I heard, was starting to have digestive problems and trouble walking.
Re: choke on this #57582
10/18/05 08:29 PM
10/18/05 08:29 PM
trollog  Offline
San Diego California USA
>>The maintanance man for the hotel was supposedly going to tighten the lugs on the main, he threw the switch to "off", opened the door, and stuck his bare metal allen wrenck into the lug...<<
no wiggy check? stupid is as stupid does...
Re: choke on this #57583
10/18/05 11:01 PM
10/18/05 11:01 PM
Attic Rat  Offline
Bergen Co.,N.J. USA
... Sounds like a candidate for the Darwin Award to me.... I feel bad for the poor yutz!!
Russ
Re: choke on this #57584
10/19/05 06:25 PM
10/19/05 06:25 PM
Any of you guys hear about the guy who tried to check a 13.2 line with his wiggy a year or so ago?
He didn't live to learn his lesson.
May have only been broadcast on local news.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Attic Rat
Attic Rat
Bergen Co.,N.J. USA
Show All Member Profiles
Admin 9
253,268 Are you busy
189,895 Re: Forum
179,610 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.038s Queries: 15 (0.006s) Memory: 1.0260 MB (Peak: 1.2030 MB) Zlib enabled. Server Time: 2019-02-20 21:38:02 UTC
