Here are some kind of detailed shots for the Locomotive Control Panel inside of an EMD model FP-45.
The Locomotive is also shown.
FYI: The Prime Mover [Diesel Motor] for this unit can be seen in the "Tech. Reference" area.
This is the FP-45 Locomotive in which the following control panel shots were taken:
Overview shot of the Legacy type control panel in FP-45 # 98,
Close up shot, showing the Dynamic Brake control and the Power Throttle [along with the "Reverser" handle's port],
Close up of the Air Brakes' control cylinders for Locomotive and Car Air Brakes.
Prime Mover shots and Trackside Signal Relays / etc. shots can be found in the "Tech. Reference" area.
Scott SET
