Look Ma! I Did It Myself!
by renosteinke - 12/04/23 02:57 AM
Scary Looking Receptacles
by renosteinke - 12/04/23 02:46 AM
Old Computers?
by gfretwell - 11/21/23 03:45 PM
Simplify MOSFET Test With Source Measure Meter
by gfretwell - 11/18/23 09:20 PM
2 members (Sonicfan20, Scott35), 14 guests, and 14 robots.
Rob Offline OP
60 amp pull out handle style disconnect serving hot tub. Total melt down on pull out.
All set screw connections were tight.
Replaced and checked amp draw on tub, 27amps
It looks like the pull out was sloppy from the factory. Unit was running for 5 yrs.
Anyone ever see Cutler Hammer products fail?
Is it possible someone didn't have it lined up properly when they hammered it back into place and bent up a contact strap?
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
TOOL_5150
TOOL_5150
Bay Area
NORCAL 1
313,348 Are you busy
239,240 Re: Forum
222,992 Need opinion
