Elk’s Lodge 11th hour ritual chime clock
by lemahj - 09/26/23 10:24 AM
Strange breaker tip problem
by gfretwell - 09/25/23 08:13 PM
An impossible Support Violation
by gfretwell - 09/12/23 04:29 PM
How are you Jersey folks about the windmills?
by gfretwell - 09/08/23 02:21 PM
Having trouble logging in?
by Admin - 09/01/23 10:26 AM
0 members (), 11 guests, and 18 robots.
#52145 05/21/05 11:37 AM
So what's the problem? I do it the "old fashioned" way...use a 4-square box with a (round) mud ring appropriate to the drywall. I cut the hole, go to the attic, set the 2x4 in place over the box, then return below to anchor the box. With luck :-) tha't my only attic trip.
#52146 05/21/05 12:08 PM
I use the Westinghouse version of the twist in place brace and it comes with a 2 in deep box. After I set the brace I give a quick hang on the bar and have never had one move.
#52147 05/21/05 02:42 PM
reno, is that 4 inch square and mud ring approved for ceiling fans? Steve..
#52148 05/21/05 04:19 PM
K
This looks like the same thing Rich linked to. If it the same they are built like tanks.
http://www.passandseymour.com/pdf/P02.pdf
