Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
AFDD's coming to the UK
by Texas_Ranger - 01/17/23 07:22 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 10 guests, and 10 robots.
#51981 05/16/05 09:57 PM
eswets Offline OP
Installed a new post light last week, and could not get the lights to turn off. Replaced photo cell three times. Voltage was correct and line and load was correct. Finally found the problem. Any guesses to what happened.
#51982 05/16/05 11:04 PM
The sun never rose that day? What?!
#51983 05/17/05 05:02 AM
Installed a new post light last week, and could not get the lights to turn off. Replaced photo cell three times. Voltage was correct and line and load was correct. Finally found the problem. Any guesses to what happened?
Here are some guesses:
<OL TYPE=1>
[*] Did not turn off Power before Connecting Photocell (AKA - Wired it "Hot"),
[*] Did not have the "Light Limiter" slider up far enough (the metallic gizmo which slides over the PC's lens),
[*] Forgot to remove the "Tape" from the Lens after testing it - or (see #4)
[*] Did not remove the protective covering from the lens - if used,
[*] Bad, or non-existent "Neutral" connection to "Common Wire" of Photocell,
[*] Load Current exceeded the max. ratings of the Photocell, forcing it into an Arced closed situation,
[*] Left it in the "Test" mode, or some slider switch setting which relates to motion / light levels, or switch overide,
[*] Photocell was getting hit from something while in operation - like a Tree's Branches blowing in the wind were hitting the Photocell,
[*] Photocell was designed to turn loads "off" when dark, or something in this realm,
[*] Photocell was marked incorrectly - like intended to be used in conjunction with another component, or it was really a motion sensing - "off" or "on" device, or Line/Load incorrectly marked (grasping at straws here)
[*] Lighting Fixture(s) Posessed by a Demon, and Demon has no tolerance for Photo Controlled Apparatii.
</OL>
Any of these come close?
Scott35
#51984 05/17/05 07:10 AM
I had a bitch of a time with photocells a little while back on street lights, had the right voltage, but the buggers wouldn't work when plugged in.
Problem: nuetral tap 3 poles down dropping the nuetral out, when a load was applied.
Dnk.....
#51985 05/17/05 10:38 AM
How long are you waiting? The photocells I have will start out "on" and it takes a few minutes before it finally figures out the sun is up. It also seems to take full sun to turn it off.
#51986 05/17/05 10:49 AM
Some PC controls have a jumper wire to select operating mode, as well. By cutting or not cutting the wire, you select "Dark=Load OFF" or "Dark=Load ON"
#51987 05/17/05 06:11 PM
e57 Offline
The piece of black tape you left over the "eye"?
#51988 05/17/05 07:02 PM
F
other possibtly is the photo cell socket bypassing the photocell circuit
or other possiblty is the photocell is line up wrong way where the eyes is not getting correct light source
or other possiblty is the line - load bypassing the photoeye circuit
#51989 05/17/05 07:28 PM
Does the post light have a ballast? If so did you conect the photo cell to the socket to photo cell. Had an apperntice do that once. Would not shut off.
#51990 05/17/05 07:33 PM
Light is shinning to close to photocell causing it to think its sun. this has happened to me.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
cookcc
cookcc
California ,Long Beach
BigB 4
triple 3
302,746 Are you busy
231,973 Re: Forum
216,690 Need opinion
