by NORCAL - 03/19/24 05:11 PM
0 members (), 260 guests, and 19 robots.
#51808 05/10/05 06:19 PM
Edward Offline OP
I noticed on my electric 120Volt-12Amp lawnmower that if i let the handle go the motor stops in 1-2 seconds if i unplug the unit while it is running the motor coasts to a stop.
Why is that?
Thanks
Edward
Thanks
Edward
#51809 05/10/05 07:34 PM
2 Possibilities.
1. The handle switch may have a mechanical brake line to the motor
2. The switch may short circuit the motor to slow it down. With the motor energized, even if it's a series universal motor, it will when spinning freely, act like a generator to a degree, short circuiting that puts a load on the motor and brings it to a stop quicker.
Unplugging the mower with the handle switch in the normal 'run' position will bypass either of these devices.
[edited to complete possible explanation]
[This message has been edited by chipmunk (edited 05-10-2005).]
#51810 05/11/05 07:32 AM
The motor has an electromagnetic braking system. When the cord is yanked(so to speak)there is no power to operate this feature and the motor freewheels to a stop.
#51811 05/11/05 08:37 AM
Good call, I missed that possibility. I'm slipping [Linked Image]
#51812 05/15/05 07:03 PM
Chip's #2 suggestion is called "dynamic braking".
Larry Fine
Fine Electric Co.
fineelectricco.com
#51813 05/15/05 07:32 PM
I well remember discovering the generator action of a motor when I was young. We had an old Morphy Richards spin dryer for clothes, with the switch operated by closing the lid. The linkage also operated a physical brake pad on the motor pulley to bring the drum to a stop quickly.
I discovered it was more fun to just pull the plug and listen to the motor slow down gradually. Then I discovered that it was slightly less fun to accidentally grab hold of the exposed pins of the now-disconnected plug while the motor was still turning at a fair rate! [Linked Image] [Linked Image]
#51814 05/15/05 07:50 PM
The dynamic braking is a safety feature. Say you realize that you're about to run over your foot with the mower. You'd want the blade to stop very quickly to avoid trimming your toes. So you release the "dead man" spring loaded power switch lever. That kills the power and switches in the dynamic braking.
#51815 05/15/05 10:34 PM
Edward Offline OP
Thanks guys
Thanks
Edward
