Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
AFDD's coming to the UK
by Texas_Ranger - 01/17/23 07:22 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 20 guests, and 14 robots.
#50787 04/11/05 06:31 PM
Is their any code requirements for using fire rated plywood. Here in CT I have seen 1/2" plywood painted with just gray paint. I have always used 3/4" fire rated. Thanks.
#50788 04/11/05 07:15 PM
I can't say if there is a NEC article (because I'm too lazy to look), but it may be covered by city codes. Many services and panelboard "walls" I have done - in NJ - have been mounted on wood with fire proof paint (black). It's gotten to the point I don't ask if it's required, I just do it. Some supply houses here have actually started carring fire-proofed plywood cut into a 2'x4' sheet
~~ CELTIC ~~
...-= NJ =-...
#50789 04/11/05 09:06 PM
So you just use 1/2" painted with gray or black fire proof paint.
#50790 04/12/05 05:41 AM
Around here (DC/MD/VA metro) we use 3/4 ply. Just generic stuff, not fire rated. I've never heard of anybody being turned down. I guess 1/2 would also be ok but for me it's too thin to get the screw to hold well.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Scott35
Scott35
Anaheim, CA. USA
BigB 7
302,738 Are you busy
231,969 Re: Forum
216,687 Need opinion
