GFCI's pops in large numbers
by dsk - 09/26/22 04:35 AM
AFCI’s Revisited
by sparky - 09/24/22 09:58 AM
NFPA Price Increase Coming
by Bill Addiss - 09/23/22 02:22 PM
Siemens breakers
by gfretwell - 09/23/22 01:45 PM
What do you look like?II
by HotLine1 - 09/22/22 12:33 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 37 guests, and 22 robots.
#49783 03/16/05 04:20 PM
derater Offline OP
Going to see the job later,but checking stuff out I find 40a GFI alone a lot more expensive than a 50a spa disco(complete) at the orange store.Probably want to use one the unit is rated(40a) for,huh; thoughts?
#49784 03/16/05 05:07 PM
Tom Offline
How about putting a regular 40 amp 2 pole in the panel & installing a spa disconnect near the spa that comes with a 2 pole 50 amp GFI?
#49785 03/16/05 06:43 PM
derater Offline OP
Yeah,40a overload/fault @ the panel and GFI @ the disco,good idea, is it kosher? Just got back from the h/o's;the co. he's getting it from has a 40a GFI x-t disco for $100 so I told him to get it; I wasn't finding one local.BTW,he called hot-to-go, but when I got there some concrete guy was taking his measurements: I chuckled.And thanks.
#49786 03/17/05 07:37 AM
How well do you know your supplier? One of my 3 main supply houses swapped the breakers for me last time (other 2 said no way). I bought the package deal and they took back the 50 and put a 40 in it.
Won't hurt to ask, all they can do is say no.
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
BEAMEUP
BEAMEUP
WA
dsk 3
297,445 Are you busy
228,280 Re: Forum
213,180 Need opinion
