752
17
I'm new to this forum and do not know how to reply to you guys when I get a response. So I'll try to explain my problem again. New vinyl siding was put up in July/04. The siding was put on over first layer original wood, second layer asphalt siding put on in the 60s. Then the siding guys came and put up isulation, one side of it white the other side foil. Foil side out. Then the vinyl siding. About 3 months after the vinyl siding was put up I noticed a ripple effect happening to the vinyl siding. It was not bad at this time. The contractor was called and said he would take care of everything in the spring. Since then the warping or melting effect has gotten worse. The warping seems to be going in a diagonal direction and is only happening on the side of the house where the power comes in from the pole, no place else. There are vinyl shutters that are also warping. The contractor was called again three weeks ago, he came down and said he was not responsible for the damage, claiming it was an electrical problem. He called the electrical inspector who said it was a bad ground, the inspector never went inside the house. But he did do a voltage test with a hand held meter and found no problems. There was a bad ground to the water pipe. It was rusty and corroded. A new clamp was put on. The power company was called and checked every thing on their side, no problems there, they also did a load test on the house (?) and also a voltage test with a hand held meter and said everything was fine. I have had two electricians come, one master and one journeyman from two different places. They tell me they have never seen anything like it and find it hard how a nonconductive material could melt or warp from electricity like that. Nothing else but the vinyl siding is effected like the window caulking or vinyl window trim. The insulation shows no sign of melting or burning, the wood and original asphalt siding are fine also. Like I said the shutters are also warping, but underneath them it is not. The warping effect is happening in a diagonal direction. The warping goes up to the shutter, the siding is warped. The shutter is warped, but not under the shutter. The warping does not effect under the shutter, then the warping continues up the house . There have been no elecrical problens to the in side of the house. This is the best I can explain things. I thank all who have responded and thank in advance anyone else.
SnakeBite, to post a reply in a thread, just click on this icon ![[Linked Image]](https://www.electrical-contractor.net/ubb/reply5.jpg) at the top or bottom of the thread. After typing your reply click on "submit now" the same as you would when posting a new topic. Out of curiosity, did the ripples start after cold weather had set in? P.S., I have copied your post here into your original thread, you can continue there https://www.electrical-contractor.net/ubb/Forum1/HTML/005595.html Roger [This message has been edited by Roger (edited 03-12-2005).]
Yes, a voltage test was done, with a hand held tester. It looked like a large pen. This was done by the electrical inspector and the electrical company, no voltage was found. The siding was put on in July and I first noticed the melting or warping in October. It was very slight. Here in the northeast it is considerably cooler in October. The siding that is effected is not in the direct sunlight, the sun hits that side of the house around 3pm, and what I did notice is that the warping or melting seems to be in the way the sun hits that side of the house. The sun hits the house in a diagonal direction, the tracks of the sun seen to be in the same direction, I think I had a hard time noticing the warping at first because at first it looked like the shadow of the sun, the way the sun hits the house. I had an insurance adjuster and a siding guy, electric company, and two electricians tell me they have never seen anything like this but do not believe this is electrical. The siding guy said it could be a manufacturer's defect called oil canning (?). The bottom line though is if the AJH says it's electrical, and the contractor who put the siding up says it's electrical, I have to prove to him and the contractor that it is not elecrical. I hope this info will help out some more. Thank you.
I think you should claim that it is defective siding and have the manufacturer do an inspection and a claim. They may rside the house at no cost to you. Is the side of the house affected the south or west side? If so, the sun and the foil may be causing this, not the electricity. I wouldn't even mention the electricity theory to the siding maker.
