Al Hildenbrand - Minneapolis - obituary
by Bill Addiss - 02/03/23 07:38 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 125 guests, and 10 robots.
Coastal Offline OP
Pardon me if this seems like a stupid question but is there any danger of damaging a commercial dishwasher whose nomenclature reads 1 phase 208 volts by supplying it with 240 volts???
That's more than 15% over the rated voltage.
That's nominal voltage as well -- If the 240V supply is running near the upper end of its allowable tolerance then it will be even more.
Would it be possible to install a transformer to buck the voltage down a little?
Coastal Offline OP
It would be possible but I don't know how practical. I'm not familiar with this type of equipment. Would it fit behind the dishwasher? Do you know of a company I could contact about such a "step down" transformer?
Try this link--
http://www.sola-hevi-duty.com/products/transformers/BuckBoost/
Then read this--
https://www.electrical-contractor.net/ubb/Forum2/HTML/001921.html
[This message has been edited by Redsy (edited 03-08-2005).]
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
lil suzi
lil suzi
Midwest
triple 3
BigB 3
303,160 Are you busy
232,170 Re: Forum
216,903 Need opinion
