#49277 03/03/05 03:36 AM
when going from 125 amps to 200 amps do i have to change meter socets at main switch gear.
#49278 03/03/05 10:25 AM
U
Depends on your POCO. Around here they provide only 100A and 200A direct metering equipment.
The enclosure and lugs of the meter base will have to be rated for the size of conductors you are using.
