Al Hildenbrand - Minneapolis - obituary
by Bill Addiss - 02/03/23 07:38 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 102 guests, and 16 robots.
#47070 01/07/05 10:09 PM
Cinner Offline OP
Before starting a unit sub we checked for continuity between phases and ground and kept getting continuity b/w red & grnd. It turns out that it was not a ground fault but only something electronically at the meter. Has anyone encountered this problem before and how do you dertermine if it is a true fault or just this electronic equipment causing this? We determined this by simply turning equipmwnt on after not physically seeing any fault in or around the equipment.
Cinner,
What sort of meter is used there?.
My understanding of an energy (KWh) meter, is that it has two coils in it.
One is the Potential coil and that connects across Hot and Neutral.
The other is the Current coil and that connects in series with the Hot wire before it feeds the load.
I'm thinking maybe that the Potential coil may have upset your continuity readings, because of a reference to Ground through the Neutral.
Can't say that I like the idea of that technique, because if there had have been a genuine fault on the circuit, things could have happened. [Linked Image]
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
BEAMEUP
BEAMEUP
WA
triple 3
303,205 Are you busy
232,202 Re: Forum
216,946 Need opinion
