#45248 11/21/04 11:59 PM
hypress Offline OP
Today I was hanging a front poarch light on a friends house. The screws that mount the fixture to the mounting bracket were to long so I cut them off and tried to screw them into the bracket and they would not fit. No problem I got anouther 8/32 it would not fit ether both 8/32??? WRONG.It seems that the mounting screws were 4mm. Now I have been an electrician for 30 years and this is the first time I have seen metric screws on a residential light fixture. Now I have seen european process equipment that'sto be expected but residential lighting??? I guess we are going to have to get metric screw cuters now. Has any one else run across this. THANKS HYPRESS
#45249 11/22/04 12:06 AM
e57 Offline
Yep, all those high end LV hand blown glass too expensive for my house jobs. My favorite is metric mounting plates, holes are set wider than 3/0, and smaller than 4/0.
#45250 11/22/04 01:04 AM
I run across tham all the time. They are in many of the cheap crap Chinese fixtures sold in the big obnoxious stores.
Now I have nothing against the Chinese, or any other race, but the quality of their products is terrible.
Speedy Petey
#45251 11/22/04 01:59 AM
If you can use a regular screw (it's not a fancy brass thing) just run the 8-32 part of your triple tap through the hole. Then it will be 8-32.
You do carry a triple tap don't you?
-Hal
#45252 11/22/04 05:56 PM
Gotta luv those tripple taps.... don't leave home without one myself.
-Greg
#45253 11/22/04 06:06 PM
We have a similar problem here in England.
Around 1970 the electrical industry switched to metric, adopting 3.5 mm threads on device boxes. Prior to that, device fixing screws were 4BA (BA = British Association).
The diameter and threads look pretty much the same at first glance, but are not interchangeable. As there are still plenty of 1950s/60s boxes in use, it's annoying to find the screws supplied with a modern outlet or switch don't fit the old boxes.
#45254 11/22/04 07:42 PM
Reminds me of "Chinese Standard Thread"
Usually 8.25 / 32 or thereabouts...
#45255 11/22/04 08:50 PM
I bought some of these to supplement my Klein triple tap.
edited for spelling http://198.247.193.8/wwwroot/greenlee/detailslib.cfm?id=20125&upc=17612
[This message has been edited by dougwells (edited 11-22-2004).]
#45256 11/22/04 09:02 PM
I call those chinese 8/32. There just metric. What I hate is when you have those chinese 8/32 trim nuts. You can't tap it out cause it's not deep enough.
Maybe the rest of the world hate those american screws. They say why are they so fat?
#45257 11/22/04 09:33 PM
Those are nice Doug. Solves the problem of having to have a tap drill and a tap. Everybody should have at least a 10-32 for those times you need to install a ground screw.
Gotta get them myself!
-Hal
