Underground phone and coax depth?
by libellis - 02/08/23 02:21 PM
Al Hildenbrand - Minneapolis - obituary
by Bill Addiss - 02/03/23 07:38 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
1 members (Scott35), 32 guests, and 12 robots.
#438 01/20/01 03:23 AM
TP2150 Offline OP
I am putting in a small laundry room in my garage. I have an electrical plug in the room currently active. I ran electricity from it to another outlet then though a wall switch connected to a single bulb ceiling light. The new and old outlets work great, though when I turn on the overhead light the 30 AMP fuse blows. I had nothing plugged into the outlets at this time. Any suggestions as to why the light is blowing the fuse.
Thanks
#439 01/20/01 06:12 AM
if the switch blows the fuse, then it's probably wired hot to neutral, creating a "dead short". Also, If you are on a 30 A fuse for this, it's not to code.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CharlieE
CharlieE
Indianapolis
303,294 Are you busy
232,253 Re: Forum
217,014 Need opinion
