Ground Rods: Installation and Hook-Up
by renosteinke - 11/26/22 07:28 PM
Happy Thanksgiving all!
by Bill Addiss - 11/24/22 08:37 AM
Colt Firearms Switchbox
by sabrown - 11/22/22 01:33 PM
Perfect work light?
by gfretwell - 11/22/22 12:48 AM
copper prices where you live and inflation
by gfretwell - 11/21/22 01:52 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 12 guests, and 12 robots.
#415 01/17/01 08:39 PM
don Offline OP
Guys I guess what my question is. What is the purpose of the end of the line resistor in a fire system
#416 01/17/01 10:41 PM
Don,
On a two wire zone the devices, pull stations, heat heads or smoke detectors short out the wires and call in an alarm but if a wire breakes off none of the devices downstream from the break will work.The solution is that the system is designed to supervise or monitor the wires and if there is a break in the wire it sounds a trouble. The way it works is the end of the line resistor connects the two wires at the very end allowing a lowered voltage to constantly flow through the loop. This voltage is not enough to triger an alarm but it is detected by the system and asures that the wires are OK. To triger an alarm the device will short the two wires togeather and the loop passes full voltage back thus an alarm. Hope this makes sense.
Dave T.
#417 01/18/01 01:49 AM
Dave,
That sounds like a good explaination to me.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
The Watt Doctor
The Watt Doctor
Humble, TX
Trumpy 3
NORCAL 3
300,280 Are you busy
229,977 Re: Forum
214,791 Need opinion
