by HotLine1 - 04/23/24 02:17 PM
0 members (), 231 guests, and 11 robots.
#40378 07/18/04 12:55 AM
wewire2 Offline OP
I can't find anyone local to repair Greenlee hydraulic tools. I have an 882 that the pump and ram leak. I also have several K.O.
pumps that leak. Should I ship them out or is it an easy fix? Thanks for any info.
http://www.greenlee.com/support/repaircal.html
http://www.greenlee.com/support/index.html
[This message has been edited by Sandro (edited 07-18-2004).]
Most hydraulic problems are simply worn soft parts like seals.
Usually you can buy a 'kit' of the soft parts and it is simple to take the item apart and replace the seals.
However be careful of spring loaded parts, a Greenlee punch head comes to mind.
If you do not have ways to deal with the spring pressure send the parts out.
Bob
Tom Offline
As Bob pointed out, there are re-build kits available. The hand pumps are a very easy repair and should take less than 1/2 hour.
Any hydraulic shop should be able to handle the rams or the KO heads. They would also be able to correct any wear on steel parts and re-plate them with chrome.
wewire2 Offline OP
Thank You
Call Greenlee and get the location of an authorized repair center.
Wewire, where are you located? I got parts for the same type of repairs from Kimmerle Bros. in San Francisco. http://www.greenlee.textron.com/support/repaircal.html
Steve
