EMC Glands on Motors
by Trumpy - 12/01/22 06:12 AM
Ground Rods: Installation and Hook-Up
by Trumpy - 12/01/22 05:54 AM
Happy Thanksgiving all!
by gfretwell - 11/30/22 05:55 PM
Colt Firearms Switchbox
by NORCAL - 11/29/22 01:04 AM
Perfect work light?
by gfretwell - 11/22/22 12:48 AM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 6 guests, and 10 robots.
#40199 07/14/04 10:43 AM
Some gas ranges and gas cooking tops require electricity for the igniters. Question: do you hard wire these, or provide a receptacle?
If a receptacle, what is the height above the floor?
Creighton
#40200 07/14/04 10:53 AM
Creighton,
Every cooktop I've seen with igniters is cord & plug connected... the igniters draw very little energy, as the 25W light in the over also... I typically place the outlet +18"AFF behind the unit...
-Randy
PS... I've come across a couple gas ranges with "browning elements" in them, which are electric. The ones I saw required a dedicated circuit per mfr instructions (1750W 120V).
Just something to keep an eye open for [Linked Image]
#40201 07/14/04 06:44 PM
Creighton, I once had a problem with the range ignitor tripping the GFI I had it on. Inspector said GFI was not needed.
#40202 07/14/04 07:35 PM
We do ours pretty much like Randy.
A recep about 18 or 20" above the floor.
Russell
#40203 07/14/04 09:53 PM
I've had requests to mount the receptacles 24" AFF for ease of access.
#40204 07/15/04 01:31 AM
e57 Offline
Another thing to watch for...
Trim kits, if the range requires any tools to remove, the receptical is no longer accessable, so you should put it a cabinet to the left or right. Some will specify which one.
#40205 07/15/04 09:51 AM
Thanks to all. In a nearby jurisdiction an installer wanted to put the receptacle on the wall above the gas range. The only thing we could find in the NEC to prohibit it was 110.11 where it speaks of excessive temperatures.
#40206 07/15/04 04:42 PM
E57 where is the requirement for the receptacles to be accessible? You can put them behind dishwashers, built in microwaves, trash compactors, etc. Why not a built in stove?
#40207 07/17/04 05:08 PM
F
Never checked it out but the amp draw of
these Igniters seem to be high as they will
not fire if you're having low volatge.Seen
this happen often.
#40208 07/17/04 05:30 PM
Accessible (As applied to equipment)Admitting close approach:not gurded by locked doors, elevation or other effective means.
Accessible readily: Capable of being reached quickly for operation, renewal or inspection without requiring those to whom ready access is requisite to climb over or remove obstacles or to resort to portable ladders, chairs, etc.
So according to the above explanation i would consider behind dishwasher,built-in microwave and a compactor not readily accessible.
Edward
[This message has been edited by Edward (edited 07-17-2004).]
Thanks
Edward
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
JoeKP
JoeKP
Berkley, MA
Trumpy 9
NORCAL 5
300,479 Are you busy
230,142 Re: Forum
214,955 Need opinion
