1 members (Scott35), 183 guests, and 11 robots.
#39589 06/26/04 11:46 AM
CRM Offline OP
I have a question on securing conduit to metal Q decking used in commercial buildings. I usually use self tapping sheet metal screws. The last job we were on concrete was poured on top of the Q decking. What type of screw do you use that first has to go through metal then through concrete. Thanks for any help.
#39590 06/26/04 12:24 PM
I've been a pretty big fan of the Tapcon system
[url to follow]
It's easy, quick, and the carbide tip should be able to punch through the decking to anchor in the 'crete above.
#39591 06/26/04 12:38 PM
http://www.itwbuildex.com/tapcon.htm
#39592 06/26/04 12:47 PM
CRM Offline OP
Thanks Doug for the help, that looks like the masonary screws I'm going to buy.
#39593 06/28/04 08:06 PM
I use a Hilti and just drill thru the decking then use the proper anchor for the job, plastic or steel a drop in
#39594 06/29/04 01:02 PM
I bang the corner of the flute with a hammer
which loosens up the concrete an a sef tapping screw will go right in.
