1 members (Scott35), 221 guests, and 11 robots.
#39223 06/14/04 07:01 PM
Joey D Offline OP
A friend of mine just got a couple of spray gun cleaners and they have a lead on them for grounding, spark contoll. What would be the best way to ground them? Ground rod at the equipment would work, block building with steel I beams on the ceiling or electrical ground.
#39224 06/17/04 02:50 PM
SJT Offline
Are these in a Non hazardous area? When I seen spray Gun, it made me think. Is it a piece of equipment that has a gounding tail ( which should be hooked up to an equipment ground conductor). I'm not sure what kind of equipment you have there.
#39225 06/20/04 01:52 PM
Joey D Offline OP
Yes they are in a non haz. location.
They need power which has hot/nuet/ground but also on the side of the unit they have a lead on them for grounding. Just got me thinking
#39226 06/23/04 06:32 PM
F
That ground sounds like it can go to building steel. Check the manual but I believe its there to shunt away the static.
#39227 06/25/04 09:22 PM
Joey D Offline OP
The building is block with a steel beam roof. I figure a ground rod would do the trick.
#39228 06/25/04 10:04 PM
You are going to have to check the manual. The lead might be for grounding the item being sprayed, so that static doesn't build up and deflect the spray. I have no experience with this, just a hunch [Linked Image]
-Jon
#39229 06/25/04 10:18 PM
No, you don't use a ground rod for anything unless it's bonded to the equipment ground at the service.
You better figure out what this lead is for. If it's connected to the ground on the supply then the machine is already grounded and another ground by this lead pointless.
Are these machines new? If yes what does the manual say? Do you have a manual? If they are used could these leads have been installed by the previous owner for some reason? Could these leads be used to ground the spray gun that is being cleaned rather than what you assume?
-Hal
#39230 06/28/04 07:42 PM
Joey D Offline OP
No they are not new.
The machine will be grounded from the panel thru a #12. I will look into this more and report back. Thanks
