Photo of the Week:
The Fine Art of Grounding
0 members (), 117 guests, and 15 robots.
#37814 05/07/04 05:49 PM
rmiell Offline OP
This may be a dumb question, but I guess I have not thought about it before.
Can I put a regular incandescent lamp (120v, 100watts) on a 125vdc circuit?
I looked quickly through a couple of lamp catalogs, and did not find any DC rated lamps, the voltage rating were just listed as 120v, or 12v.
thanks
Rick Miell
#37815 05/07/04 07:12 PM
yes, you can put a standard bulb on that circuit. however, you may wish to use "commercial" 130V bulbs rather than 120V bulbs since your circuit is 125V
#37816 05/08/04 12:34 AM
Incandescent lamps run fine on DC. One hitch though—most flush toggle switches are AC only. For tungsten-lamp switching, a DC {“T”} tungsten-rated switch is needed. They make plenty of racket during operation …none of that quiet AC-only stuff. They are listed as AC-DC General Use Snap Switches — UL Guide WJQR.
#37817 05/08/04 11:10 PM
F
Rick.
most indscent lamps can run on dc with out any troble but bear in mind that the dc verison will run slightly dimmer but not a whole alot but bulb life will be little longer too also.. i am not sure if you know this or not when bulb fail they do flash over pretty good btw just like 277 volts ac bulbs go out simuir idea so i dont know but i will guess you allready knew this or not put a over current device there to prevent serouis arc falut.
as far for switch use the genral usage snap switch .
merci , marc
p.s. i did work on one tug boat before it ran everything on dc before so i got pretty good idea how it react with it .
#37818 05/09/04 04:51 AM
Filament lamps run on DC just fine, and if connected to a 125V DC supply you will obtain the same amount of illumination as on a 125V RMS AC supply.
Switches need to be the "quick-break" type for DC operation. The common "tumbler" switches used in this country when DC supplies were common employed a spring-action contact and opened and closed with a really noticeable clunk. The quiet AC-only switches will end up with burned contacts if used on DC.
#37819 05/09/04 08:37 AM
Will these switches work too?
[Linked Image from joetedesco.com]
#37820 05/10/04 01:56 PM
rmiell Offline OP
Ok, Thanks guys.
These lamps will be run thru a contactor, so switching will not cause a problem.
I knew you guys would give me a straight answer!!!!
Rick Miell
#37821 05/11/04 11:57 AM
Joe, what were you doing at my mother's house? [Linked Image]
She still has a few of those and they work like brand new. Amazing, for being 80 years old now.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
noderaser
noderaser
Portland, Oregon, United States
344,457 Are you busy
269,757 Re: Forum
250,420 Need opinion
