Photo of the Week:
Mouse on a Bus
Mouse on a Bus
0 members (), 111 guests, and 26 robots.
#3667 08/25/01 11:18 AM
V
voltage Offline OP
What happen to a 3 phase meter with three current and voltage coil with neutral, if its incoming two phases are interchanged at the meter terminal? Desperate to know the answer. Anybody help, please...
#3668 08/25/01 12:14 PM
Remember it is a watt hour meter, it is only measuring watts used. It should not turn backwards, quit working, or anything desparate like that. Rearranging CT's alone affect nothing, rearranging phases only affects rotation of the 3 phase motors in the system, and not the meter. Also, 3 phase hermetic compressors will not be affected at all. they either go down and up, or up and down.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
HappyElectrician
HappyElectrician
Penn USA
340,313 Are you busy
265,711 Re: Forum
246,717 Need opinion
