A 5-20(20a) receptacle is legal on a 15a circuit?
by libellis - 10/10/21 12:46 PM
GFCI's pops in large numbers
by dsk - 10/07/21 03:46 PM
Backup Generator Done Right
by timmp - 10/06/21 02:07 PM
How's all our Non-US folks doing?
by dsk - 09/30/21 05:06 AM
Well I am back to stay (nearly 6 years)
by Bill Addiss - 09/26/21 11:09 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 4 guests, and 15 robots.
#35978 03/25/04 11:39 PM
Anonymous
Unregistered
Has anyone seen 8/2(with ground) UF? I can find 8/3 in UF but only 8/2 in NM.
Thanks, Brian
#35979 03/25/04 11:51 PM
Brian
8/2 UF with ground is available at www.gesupply.com . The part number is 8-2 WG UF RL. I have never used any but it is in my catalog.
Kevin
#35980 03/26/04 05:30 AM
Brian, can I ask what you are feeding with the 8/2?
Bob
#35981 03/26/04 10:28 AM
Anonymous
Unregistered
Thanks Merlin.
Iwire, it's for a 30A 120V RV hookup. The run is too long for #10.
Brian
#35982 03/26/04 05:34 PM
Brian if you have a sharp inspector they will notice that grounding conductor is to small.
250.122(B) requires the grounding conductor size to be increased when the other conductors are increased for any reason.
In the case of a 30 amp circuit you need a full size grounding conductor, run 8 AWG hot & neutral and you need a 8 AWG ground.
You might want to use the 8/3 and ask the inspector if he has a problem with remarking the red to green or just stripping the red to bare.
Good luck, Bob
#35983 03/27/04 08:18 AM
I've never priced 8/2 cable, but would not 8/3 be cheaper as its much more common? Just a thought.
#35984 03/27/04 09:28 PM
Anonymous
Unregistered
Thanks for the replies. I never thought about the grounding conductor. Guess I'll ask the inspector first, if he balks it will be time for pipe and THHN/THHW.
I've always wondered about re-marking a red, white or black conductor as a grounding conductor and in fact I've done it on occasion however there were no inspections.
What are most AHJ's position on this?
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Theelectrikid
Theelectrikid
Levittown, PA
dsk 5
284,584 Are you busy
217,283 Re: Forum
203,638 Need opinion
