Using THWN on automotive circuits
by BigB - 03/22/23 09:46 PM
Continuous load
by HotLine1 - 03/08/23 02:11 PM
How's all our Non-US folks doing?
by dsk - 03/08/23 11:56 AM
Old Computers?
by Bill Addiss - 03/04/23 05:06 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 12 guests, and 48 robots.
Would anyone happen to know the years certain types of wire were used (i.e. Cloth, aluminum, etc.)
Don't quote me, Aluminum wiring was in the late 60s to very early 70s. Cloth Braid wiring has a long history, and mostly was taken over by TW in the late 50s early 60s.
NM cable without an EGC was actually produced in the late 30s or early 40s.
If you were to go to Google, type in the history of wire installations and you can find some good stuff.
Pierre
Pierre Belarge
For aluminum building wire, AA8000-alloy wire started to replace EC1350-grade material in ~1977-78.
Note that by NEC, 1350 alloy is still permitted for type-USE cable.
A great reference is Old Electrical Wiring Maintenance and Retrofit
by David E. Shapiro. Perhaps your local library has a copy--it's out of print.
C-H Offline
You can read the first 30 pages on the link ThinkGood provided.
The same author has also written Your Old Wiring which appear not to be out of print.
{How can you possibly need to edit something as simple as this three times???}
[This message has been edited by C-H (edited 11-28-2003).]
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Alan Belson
Alan Belson
Mayenne N. France
BigB 2
triple 2
304,960 Are you busy
233,373 Re: Forum
218,105 Need opinion
