Photo of the Week:
Electric Cow Catcher?
0 members (), 46 guests, and 19 robots.
#31163 11/11/03 10:40 PM
Sandro Offline OP
Changing ballasts in a strip mall today, there was a 347V HO ballast working a single lamp fixture that was burned out. I opened it up, and to my surpise, it was a 2 lamp ballast. The red leads connected to one end of the lampholder, the blue leads connected to the other end of the lampholder. The yellows (common) was capped. I've never seen such an installation before, yet when I replaced the ballast, the single lamp worked fine again. Is it common to wire single tubes this way? I've never seen it, and the wiring diagram and info on all the 2 lamp ballasts I've ever seen relates to 2 tube setup.
#31164 11/13/03 11:30 PM
Sandro;
As strange as it seems, that is actually the preferred method of driving one F96 T12 Lamp using a Two-Lamp Electromagnetic ("Older") Ballast.
Scott35.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
Alan Belson
Alan Belson
Mayenne N. France
333,432 Are you busy
258,768 Re: Forum
240,184 Need opinion
