1 members (Admin),
145
43
Here on Long Island, quite a few homes have excessive humidity build-up of moisture on the water main pipe that enters the home. What I normally do during a service change is to Scotch-Kote the clamp and surrounding area of the pipe. Too many times have I seen the clamps severly corrorded. With the scotch-kote on the corrorsion stops, and years later you can check the clamp like it was new. I would like to see this as part of the code, but I think the breathing of the fumes of the Scotch-kote might be an issue. Any ideas? Steve T.
a similar idea i have used with split-bolt connections is to wrap them in a layer of dux seal before tapping them up. the same theory applied.... (learned that one from an AHJ!) ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
Posts: 4,156 Likes: 5
Steve, Welcome back! I was thinking maybe clear lacquer. Don't they scotch-kote furniture? I can't see how it could be that harmful (except maybe while spraying?) If you know the chemicals involved or a specific brand you can look up the MSDS info. Try here: http://www.hazard.com/ Bill
Posts: 2,236 Likes: 1
That would be scotch-guard...
Scotch Kote is an "electrical" sealer... Don't get it on your skin!
'66 OooooKay! ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif) Hey, You don't know what kind of Furniture I've got! That's what I get for makin fun about your "Coherent" threads Steve, Sorry about that! Been puttin in some big hours here! ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif) Bill
There seems to be quite a few different types. If you go to the following page and enter "Scotch Kote" where it says Trade Name it will bring up a list of MSDS for the different types. http://products.mmm.com/US/MSDS/msdsSearch.jhtml
To the best of my knowledge, oxides of copper are still excellant conductors, unlike aluminum oxide which is more of an insulator. If I was to pick a product to use, it would be "Copper Kote" by T&B, applied between the clamp & pipe.
WOW!
I never realized there were so many different types!
I'm going to look at a bottle at BGE tomorrow to see which type I usually buy when needed.
BTW the ScotchKote I use tends to weaken the jackets of SOW cable. Learned that one the hard way in a fountain light installation. (no one was hurt). I hardly have used it since then. My buddy (and fellow EC) Joe M. got some on his exposed (river shoes) foot (don't tell OSHA) and had an ulcer for about a month on the top of his foot. Nasty! (In his defense, he had to wade out in 1.5' of water to make the repair) I have used it to WP submersible pump connections since, however. The remainder of that bottle ended up as a 1/8" deep mess in the back of my truck... Got the lid on crooked... Remnants remain on some of my tools...
Uhhh.. So much for coherence!
[This message has been edited by sparky66wv (edited 07-27-2001).]
I've found that ScotchKote may not be compatible with other brands of tape. Best if you apply it over other 3M products. When it works, it does a great job, when it doesn't it makes a mess.
