#27588 07/22/03 03:02 PM
donles Offline OP
Forgive me if this has been asked recently but I searched the forum and googled the 'net for a circuit breaker compatibility chart.
Has anyone documented what breakers will fit other manufacturer's panels? I'm talking residential.
Don
#27589 07/22/03 03:35 PM
Just because they fit doesn't mean that you can use them. If they are not from the original manufacturer, then they must be UL "classified" for use in that panel. All classified breakers come with a listing of panels that they are permitted to be used in. Use of breakers that "fit" but are not listed of classified for use in that panel is a code violation and a safety hazard.
Don
[This message has been edited by resqcapt19 (edited 07-22-2003).]
#27590 07/22/03 06:16 PM
donles Offline OP
OK. I'll rephrase the question.
Has anyone documented what breakers are UL classified for use in other manufacturer's panels? Or is that generally not done?
Don
#27591 07/22/03 06:57 PM
You may be able to find out @ UL's website (if you can figure out how to navigate it} [Linked Image] . Good Luck !!
Donnie
#27592 07/22/03 08:36 PM
I don't know of any published list. The information is required to be on the classifed breaker or its package.
Don
#27593 07/22/03 09:09 PM
I was wondering the same thing. I know that Siemens and Murray are exactly the same and should be listed for each others panels since they are made on the same line, just diferent stickers. I know Siemens will fit in a GE, but a GE doesn't quite fit right in a Siemens. Square D homeline fits a Siemens, but Siemens doesn't fit a Homeline. Cutler Hammer makes a breaker specifically to fit a Square D QO, so I guess it's listed.
Our trucks are stocked with a wide array of breakers so we don't mix and match unless it's an obsolete panel, like Challenger, then we use a Siemens.
I really would like a list of "legal" breaker cross referrences.
#27594 07/22/03 11:51 PM
donles Offline OP
I'm glad you agree with me. I'll post here if I find anything. Or maybe I'll research the subject and report my findings.
Don
#27595 07/23/03 01:34 AM
For electric eagle.
I think the proper replacement of challenger breakers is cutler hammer. Challenger was part of westinghouse and westinghouse became part of cutler hammer.
#27596 07/23/03 04:17 AM
Just as an aside there, guys,
Over here in NZ, this very topic is a real sore point with us Electricians.
In that, competitiveness, between the Manufacturers of Switchboards/MCB's, is such that, the one manufacturer, will make thier board to only accept thier range of Breakers, it's all OK, until you go to fit the front panel back on the board, after you have finished the job, and they don't fit!.
They are all DIN Rail mounting, but the front pieces are slightly different in width.
Sure, you can rip the panel out, but why?.
#27597 07/23/03 07:54 PM
Cutler Hammer has a line of breakers listed for use in alot of the more popular panels.
