ShoutChat Box
Questioning the electrical norms
by LongRunner - 09/23/20 06:38 AM
Smoke & mirrors?
by HotLine1 - 09/21/20 03:42 PM
Pool Lights?
by Papa - 09/18/20 05:26 PM
Ever been afflicted by Gout?
by mbhydro - 09/15/20 05:50 PM
120/208 gives 240? please clarify
by NORCAL - 09/13/20 01:08 AM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 15 guests, and 11 spiders.
sealtite ? #25275 05/03/03 09:21 AM
Cindy Offline OP
maybe i dont know what sealtite is..... i thought it was a generic term for LFMC & LFNC like romex is for NM ???
Re: sealtite ? #25276 05/03/03 09:31 AM
Obsaleet Offline
I believe you are correct. NEC 2002 Art 350
Phil
Re: sealtite ? #25277 05/03/03 10:03 AM
elektrikguy Offline
Sealtite is actually available in all trade sizes from 1/2" to 4". It is used in areas where dampness and moisture is present. It is similar to "greenfield" only is has a continuous rubber coating on the outside. It requires some very spendy connectors when you start dealing with 3" and 4" 90 degree. Those who have bought and used will know.Hope this helps.
Re: sealtite ? #25278 05/03/03 12:17 PM
The Watt Doctor Offline
Be careful when you buy it. If it is for outdoor use, it needs to be UV rated. Believe me, there is "nonUV" rated sealtite out there for in door use, and some times supply houses will send what they have on the shelf without asking you what type you need.
Regards,
Doc
The Watt Doctor
Altura Cogen
Channelview, TX
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Radar
Radar
Los Angeles, CA
Show All Member Profiles
Trumpy 8
NORCAL 3
270,004 Are you busy
204,406 Re: Forum
192,619 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
